4 weeks ago
I subscribed to this plan and the description left me confused, (ie; Unlimited Canada an US wide minutes and messaging...) Does this plan in fact include unlimited phone calls from Canada to the US.
4 weeks ago
you're good to go whether in US or Canada you can use all your PM talk/text and data in your plan without worry of additional surprise costs or overages. You'll be able to call most any US or Cdn number from either country. For optimal talk usage...just confirm if you have volte enabled cellphone.
4 weeks ago
If you look at Hairbag1's answer you will see the plan referred to.
Thanks
4 weeks ago
Thank you for the info, the plan you show is the plan I'm subscribed to.
4 weeks ago
\here's a list of the cellphones that PM has whitelisted for volte...
To check if your device is VoLTE-Roaming enabled, please check this list:
As long as you have a cell that's on this list you should have great talkability whilst in US.
4 weeks ago
it means you have full access to talk / text and data, just as you would at home. It's a great snowbird plan. Just make sure you have a cellphone that is volte enabled. PM has a limited number of cellphones that they've turned ON volte. Also, you should enable Roaming Data in settings and just leave it on. When you're in US, you'll connect to AT&T or T-Mobile only..no others will work.
4 weeks ago - last edited 4 weeks ago
This plan should provide full service in both countries.
But $40 plan I see through my account provides 75GB of data? What plan did you take???
