02-27-2017 05:48 PM - edited 01-05-2022 01:46 AM
Is there any way to view the data usage in a graph or some better format then having everything mixed together? I know you can have it ordered by data at the top first, but even when I do that I cannot see my data usage earlier this month before the 7 days even if I change it the usage to view 90 days.
11-29-2024 11:21 AM
Wow. So 7 years after the suggestion and they still haven't implemented it? How useful is showing daily data usage when we are invoiced by month??? Perhaps I'll got re-suggest it
04-19-2017 08:05 AM - edited 04-19-2017 08:08 AM
Here you go folks,
Here is the spread sheet for the manual process of Usage calculating.
There are instructions in the first tab of the excel file.
It's very basic, Iam sure someone can improve on it.
Next upgrade if I ever get to it is to have a script to pull from Public mobile site. But I think you can use a newer excel version that can convert web to excel. Havent tired yet cause I got an old version of excel. If anyone has the latest let me know if you can.
Thanks,
http://s000.tinyupload.com/?file_id=88254557178537811775
Virus free - please do run a scan anyways to be safe.
02-28-2017 08:58 AM - edited 02-28-2017 09:01 AM
I can send you a copy of my spread sheet it tracks it in great detail but sadly you must input the data manually until i have finished writing my script to pull from public mobile site.
It graphs: Data usage, Call type, most common numbers for now but it can do so much more later... when I have time to play around with the data.
It currently tracks the below:
27/02/2017 12:45 | Information Last Updated |
6000 | Data Plan MB |
5292 | Data Used MB |
88.20% | Used in % |
11.80% | Unused in % |
UNUSED DATA LEFT in MB | |
708 | Total Left |
708.00 | Per Day |
29.50 | Per Hour |
0.49 | Per Min |
3/1/2017 | End of Contract |
1 | Days left on Contract |
02-27-2017 06:12 PM
@Shutdown wrote:Don't want an app to track data usage I am fine with checking PM web for total usage I was just wondering if there was a way to get a better formatted table or graph of data usage for this billing period, seperate from text/calls.
No there is not. Under the Usage History, you will see your usage but that will include texts and calls. I know that its really difficult to go page by page to find data usage as you may have several texts or calls. That's why i have suggested an idea to allow data/calls/text selection to sort the history.
02-27-2017 06:01 PM - edited 02-27-2017 06:02 PM
02-27-2017 05:56 PM
Here is the post reviewing that Data witness app suggested above: http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/IWIK-s-quot-Data-Witness-quot-for-Andr...
02-27-2017 05:53 PM
