11-30-2016 02:22 PM - edited 01-05-2022 01:05 AM
To those who have been hesitant of porting a Koodo number through self-serve:
I just ported successfully through Public Mobile's self-serve from Koodo, at 11AM Nov. 30.
It took 30 seconds for the web page to tell me that the port completed. 5 minutes later I checked and the SIM was active with my old Koodo number. Everything works. I also checked Koodo's self-serve page and it has already updated. I see a bill with the Tab Payoff and the prorated partial charge for my current billing cycle.
The information I provided for the port was my Koodo account number and my phone's IMEI.
What a pleasant experience. Never knew switching cell provider could be so simple!
Edit: Though, I do have to say that the email support of Public Mobile has been unresponsive for over a week already, which is why I decided to give self-server a spin. ![]()
12-01-2016 11:41 AM
I ported from koodo and the whole process was completed in less than a minute
12-01-2016 09:43 AM
12-01-2016 06:47 AM
12-01-2016 06:41 AM - edited 12-01-2016 06:43 AM
Pay as you go. Should it make difference? I think It should not.
11-30-2016 10:38 PM
11-30-2016 09:13 PM
Hi Grimalkin,
No luck. same error when click Check Eligibility. I did logout, cleared the cache and restarted browser.Cleared cache again, log out and restarted again.
I am trying since last two days. Definetly there is problem at Public Mobile Chnage number process.
Seems you are lucky!!
If any one has any suggestion, highly appreciated.
Thanks
11-30-2016 08:29 PM
11-30-2016 08:26 PM
11-30-2016 08:04 PM
Hi Grimalkin,
Thanks for the guide.Just to confirm, I have different login email for both. Activated PM with new number (as suggested during activation process). Now when I try to port Koodo number to Public Mobile. I am getting error and not pass the first page.
I followed the steps as:
1. Login to My Account, then Change Number
2. Click Radio Button Transfer a Wireless or wireline number from Public Mobile or another provider.
3. Checked the box I am authorized to transfer this phone number
4. Input in my Koodo number that I want to port.
5. If I click Confirm button than get error message "You must be authorised to transfer this number"
6. If I click Check Eligibility (after fresh start and done steps up to 4 as above) than get error message "We are experiencing difficulties in processing this request. Please contact Public Mobile for additional assistance"
Would you please suggest what wrong I am doing? As per the error message, I have submitted a private message to one of the moderator with all the required details. Still the private message is not read by moderator (I understand that due to heavy volume they are busy, however it is difficult to not get status update).
Thanks in advance.
11-30-2016 04:40 PM - edited 11-30-2016 04:49 PM
Just to confirm the koodo process, I just did it with 2 numbers.
1. Make sure your email is different than your account on Koodo (make a free email if you need to for this purpose).
2. When you go to port the different number check the box that you are authorized, then put in your number that you want to port.
3. I used my account number for verification (I was told this is the only way with Koodo).
4. I used the primary account holder's name (it wasn't my name, it was my wifes).
5. Alternate phone number doesn't matter really, just don't use your own number or any numbers associated with this porting.
Note: When you activate your SIM, get a new number, then go into your PubliMobile account and do this after the fact.
Took 30 seconds to process on the website, SIM worked right away on my locked koodo iphone. Phone is still locked and it works great with Public Mobile.
11-30-2016 02:47 PM
Congrats on port & welcome to Public
It *usually* is painless, just last few weeks have made most nervous
11-30-2016 02:24 PM
That's great to hear.
Welcome to Public Mobile and thanks for sharing your experience.
