usage history not updated
Maselina
"We’re currently experiencing an issue where your usage history may be presented out of order. We're actively working to fix this issue and appreciate your patience."  This statement has been on my account page for more than a few weeks.  Is the issue not fixed yet?
will13am
This problem seems to be pandemic like.  All my accounts have the same issue.  Correction, the usage history notification appears to be incorrect.  I just made a call to see if it would register and it did.
@Maselina
For mine, I see both calls and data. Try again using Incognito mode and see if you see the correct usage log
If you still see calls missing on the log, you might want to engage support by direct message for further investigation:
Maselina
I saw updated data but not phone calls.
@Maselina
are you not seeing the correct usage?  For mine, the usage has been updated without any issue
Did you not see any updated usage at all?
