07-27-2022 02:53 PM
Tried to log in and sent to authentication and back to sign in page numerous times ,,, sometimes I ge a page expired response other times just get another authentication page just checked have been authentication coded 7 times,
Tried SImon and got irrelevant responses including do you no want to be a customer. keyed in new self service address and got into similar round trip
What gives..?
07-28-2022 11:52 AM
Thanks to everyone who offered a solution... This has been a painful experience.
I did the sleep on it overnight thing and managed to wend my way in via reset password again... and finding where my password manager stored the saved results under a very long TELUS address without the Public Mobile identity sure helped. Anyway I finally was able to add data a week before Auto pay came into play...
Thanks again
07-27-2022 08:52 PM
@IcebergalleyTim - sounds frustrating. With the latest upgrade to self serve I still see some bugs. Perhaps these are affecting you too?
If you have created a self serve account and you are having issues logging in, and try clearing your browser's cache, or try a different browser or device, or opening a tab in incognito mode is not helping, than hopefully a CSA can help.
Also, too many failed attempts may temporarily lock your account access. Try waiting 3+ hours before you try again.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
NOTE:
If you have been in nonpay/suspended status for over 90 days, then you lost your Public Mobile account, phone number, and access to self serve.
07-27-2022 05:36 PM
Now I'm locked out The new password hid in my password manager under Telus and kept coming up from my old one under Public Mobile and now it is in a Telus identity page that I don't use
07-27-2022 05:13 PM
tried incognito and got same result.. Thanks for helping...the agant has not responded and the phone still works at least for txt..
07-27-2022 05:00 PM
I cleared the cache and cookies and I also tried on my phone browser and keep getting sent back to authentication.. No access to my account... one note said I was to try at unspecified time (null) later because of too many tries. I keep thinking Rogers %^&*() up type but at an small scale..
07-27-2022 03:23 PM
@IcebergalleyTim Hi I’m not sure why this is happening to you , try deleting your cache and cookies try using a different browser in secret or incognito mode
07-27-2022 03:20 PM
still happening
07-27-2022 02:59 PM
contact a cs agent
you can private message them here
