11-21-2016 12:34 PM - edited 01-05-2022 12:46 AM
Hi,
recently I have switched to PM from Rogers. I have noticed that my battery drain by cell stand by and this is the highest in the batter usage. anyone has similar issue?
thanks
aj
11-21-2016 06:46 PM
11-21-2016 06:24 PM - edited 11-22-2016 10:02 PM
You are not alone. I noticed the same issue with Cell standby on S6. I have searched online but still unable to find a solution.
11-21-2016 12:52 PM
if you are using android phone it will drain your battery ,my blackberry passport stays charge for 3 days since i keep my notification on it does drain battery
11-21-2016 12:45 PM
yes, same and it was unlocked.
its s6
11-21-2016 12:37 PM
I switched from Rogers and haven't noticed anything different. Are you using the same phone as you were with Rogers (ie it is an unlocked phone)
