11-02-2020 06:23 PM - edited 01-05-2022 04:00 PM
I purchased a $15 add-on for u.s. calling and it showed up as payed but when i try calling to the u.s. i keep getting a message saying i don't have an active long distance add-on. I probably did the first step wrong by not putting funds in first...but what do i do from here?
11-02-2020 07:25 PM
@sue02 wrote:Actually, it didn't show up in the available funds but it did take the amount from my credit card. That's why I'm thinking I did that step wrong. But i don't want to pay it again.
@sue02 , try retracing your steps against this illustrated guide. This will help to determine what went off the rails.
11-02-2020 07:21 PM
@sue02 you can contact customer support mods if your credit card was charged.
make sure to check your inbox(top right corner envelope icon) periodically, for a response
11-02-2020 07:20 PM - edited 11-02-2020 07:21 PM
Login to your self-serve account.
If you have $15 or more as the available fund, your did not purchased your add-on yet. Buying add-on is a 2 steps process. After adding fund ot you account, you need to purchase the add on with the fund in your account.
11-02-2020 06:48 PM
11-02-2020 06:39 PM
@sue02...
log into your account / My Data & Add-ons to see if it's there in your account.
11-02-2020 06:37 PM
Do you possibly see the add-on parts in your overview page under my data & add-ons? Or the Plan Details page?
What is the area-code/prefix you're trying to dial? (not last 4 digits)
11-02-2020 06:33 PM
11-02-2020 06:27 PM
@sue02- If you only did one step, what you actually did was put funds into your account ($15). Check your account balance in self serve to confirm.
What you need to do now is purchase the add-on. It will take the funds from your account balance.
11-02-2020 06:27 PM
@sue02 wrote:I purchased a $15 add-on for u.s. calling and it showed up as payed but when i try calling to the u.s. i keep getting a message saying i don't have an active long distance add-on. I probably did the first step wrong by not putting funds in first...but what do i do from here?
Yeah it's not very intuitive. You probably see your $15 in your Available Funds. Now go and actually buy the add-on. You did the first step of depositing money so as to be able to buy the add-on.
