10-07-2016 06:11 PM - edited 01-04-2022 03:38 PM
10-07-2016 06:28 PM
hi..
what i would do: send yourself a text message... log into your account and under "usage" you will see it if your phone doesn't show it, which it should.......
10-07-2016 06:27 PM
It should automatically load your number.
Can you text or call? Call/text a friend to find out your number or simply login to your self-serve account here: https://selfserve.publicmobile.ca/
