4 weeks ago - last edited 4 weeks ago by computergeek541
Hi all,
I will be in the US soon, and have the following plan...
Does this mean that I have access to data in the US and just need to add on talk and text if I want to be reachable? Thanks
4 weeks ago
hi @omegaman
no need to add roaming plan or addon as you already have the $34 Canada/US plan
4 weeks ago
Hi @hTideGnow so just to confirm, I do not need to add on a roaming plan as I have full access to data, talk, and text? I read the plan as Canada to US hence my confusion
4 weeks ago
You're still roaming when you're in the US, but it's included in your plan so there are no extra charges and no add on required. You'll want to:
1) Turn Data Roaming ON
2) Set Network Selection to AUTOMATIC
3) Set Preferred Network to 4G/LTE (because roaming on AT&T 5G doesn't work)
4 weeks ago
HI @omegaman this is a Canada-US plan, you get data/text/voice in BOTH US and Canada. So, no extra needed
you just need to turn on Roaming data and make sure your phone connected to T-Mobile or AT&T. Sometimes, you need to manual switch for better connection
