Sim Card
Someone_else
Hi. Where or how can I purchase an discounted sim card?
Someone_else
Thanks for the solutions. I actually was trying to buy the sim card for $5 at PM when it was on sale recently, but when I put it in the cart it automatically went up for $10, so it didn't work. But I was able to get it from Amazon for $5 and got it in only 2-3 days.
LibraryMichelle
New Neighbour / Nouveau Voisin
Additionally, if you use a referral code from an existing PM customer you get a $10 credit on your account, which pays for the SIM. Good luck
Andy85
Hi @Someone_else ,
You can order SIM cards several ways.
  1. You can order a Physical SIM directly from the Public Mobile website! You can have the card delivered straight to your address!
  2. You can order an eSIM (electronic SIM) directly from the Public Mobile App and start using it right away.
  3. You can pick up a physical SIM card from a nearby store. To find out which stores near you sell physical SIM cards, you can go to https://www.publicmobile.ca/en/qc/pick-up-SIM and enter our postal code. The site will then suggest you stores closest to you that sell SIM cards.
