Roaming data not working
jameschambers
I've set my APN parameters to what is recommended for my phone in this forum.
I have a Samsung Galaxy note 8, updated to the new Pie OS. I paid $20 for the talk and text +  250mb roaming data plan. I can receive texts and make calls but my data isn't working. I am in Hawaii, if that helps.
Please someone help me!
14 REPLIES 14
@jameschambers wrote:
SOLVED!! several layers of settings caused the problem. Data roaming was off, the APN settings needed to be changed and my personal favorite, 'my partner turned the general mobile data setting to off' which disabled me from changing the APN which disabled me from turning on the roaming data setting!
Thank you so much everyone. I love you.
Now back to the vacation I can't afford (which is why I have public mobile!)
BLESS ALL OF YOU
Time to have fun roaming around!  Smiley Happy
Mary_M
Retraité / Retired
Retraité / Retired
glad to hear that you figured it out! Have fun 🙂 @jameschambers
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
jameschambers
BLESS ALL OF YOU
I've made calls and sent and recieved texts
If you can make calls, but not data,   it is most likely due to roaming setting on your phone then.
Yes! Thank you! I see the setting but I can't turn it on.
Does this describe what you are seeing?
https://support.bell.ca/mobility/smartphones_and_mobile_internet/samsung-galaxy-note-8.how_to_turn_d...
Alright good.
There might be an overall setting that blocks you from roaming to begin with as well.
jameschambers
Did you get a text from Public Mobile welcoming you to the states?
If not then you probably need to manually scan for and connect to either AT&T or T-Mobile.
jameschambers
Are you sure about the make calls?
Can you receive calls?
Can you send texts?
Is the add-on showing in lower part of your overview page?
Do you still have the $20 in your Available Funds?
Can't make calls successfully if the add-on purchase was not completed.
I agree. That's why I wanted to verify.
Can you send texts?
Metal1967
@jameschambers
Does your phone possibly have a seperate setting for data roaming that needsto be turned on?
will13am
@jameschambers, have you enabled roaming data on your phone?  Search this function from the settings menu.
Can you send texts?
