Rewards
Rock78
Am I going to lose my referral rewards when public mobile changes to points?
HALIMACS
@Rock78
if the folk(s) you referred decide to leave for any reason, that’s where you will lose out since their referral value will be removed.
otherwise, it’s one of the holdouts as far as rewards go with the change from Legacy rewards to public points.
Meow
YES!
Only referral stays but it will be 1 referral = 1 point.
No more loyalty $, autopay $; every year you will get 10 loyalty points.
The referral offering will change from a $1 credit to 1 point per active referral. Each point is worth a $1 credit but redemption must be done in multiples of 15 points.
