Rewards, bonus data/minutes from 3g plan to 4g plan
jearmstrong61
If I switch from a 3g plan to a new 4g plan will my bonus data & minutes transfer over to the new plan?
Yummy
Everything stays the same. These are just new 4G Plans and process of changing from one Plan to another did not change.
dust2dust
Freebies will stay. If you have bonus data from a promo under the promo area on the right side then that could be at risk. Although it really shouldn't. But 3G to 4G are different animals. As long as you stay up in plan cost then theoretically it should be fine. But as always YMMV.
Adding - minutes will stay.
MrSpock
@jearmstrong61 hi any bonus data or bonus minutes will indeed transfer over
