Re-send Telus text to switch providers
Zodo66
Hi.  I tried to do the provider switch from Telus to Public.....but I missed the timelimit for accepting the Telus switch.  How do I get it resent?
Thelastjedi
Ok, I see. Thanks!
Nope @Thelastjedi
When porting, it's all on the new provider to make the request to pull the number from the prior provider.
Once the OP contacts the number that is being sent to them by @TheSterlinger , Public Mobile will make a request of the original provider that they release the number to public mobile.
The new provider then sends a port authorization request SMS to the Customer,  they reply YES, then put the public mobile SIM card in their device.
Thelastjedi
Hi there, in this case you would need to contact Telus to ask them send you the mobile number transfer request again. You could call them or reach Telus by Online chat in telus.com.  Thanks.
TheSterlinger
Contact the porting department for Telus. I will send you the number, check your inbox.
