2 weeks ago
I've recently activated a new SIM card and started the process of porting my number, but I've encountered a problem. When I try to make calls using another phone, it doesn't work—I get a message saying 'your call has been forwarded.' However, when I use the newly activated phone, I can call any number without issues. The problem arises when I try to complete the setting for 'Confirm for full access' as I'm not receiving the code.
2 weeks ago
HI @Nazila
but did you get the code on your old sim card with the old carrier? Put it back and check
if you really cannot complete the activation, please message support agent for help
2 weeks ago
I have the same issue. Did I not receive the text with code to complete the setup.
2 weeks ago
I haven't activated the new carrier (but activated the NoName SIM card two weeks ago). It was supposed to be activated yesterday, but I haven't topped up any credit. Therefore, I can't use the old carrier. Until yesterday, I was with PM and was working. Yesterday, I was supposed to switch to NoName, but since I didn't top up any credit, it's not working.
2 weeks ago
Did you get a text from the old carrier, did you reply YES?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone? If you cannot the port was not done
It could be an incomplete port. PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
