03-03-2018 03:33 PM - edited 01-04-2022 03:39 PM
Such bad customer service or lack of customer service I should say. I'm commenting on this thread hoping my query will get attention.
I signed up for Uber with my newly activated public mobile sim and Uber sent me a 4 digit code vIA text which I am not getting! ! Apparently public mobile might be blocking some texts....
03-03-2018 04:46 PM
@Wafaimran, are you getting any calls? If calls are also not coming in, then there is likely a porting issue.
03-03-2018 04:45 PM
Are you receiving calls?
Did you recently port?
03-03-2018 04:44 PM
Thanks for the reply!! I have the galaxy note edge. I can send texts and the recipients are getting them. But I'm not receiving any🤔😐😠
03-03-2018 04:44 PM
@Wafaimran, Time to send a private message to the moderators team, so that they can get things corrected.
Click here to send them a private message.
You can find information regarding the moderators team by following this link.
03-03-2018 04:42 PM
Hey thanks for the reply!! It turns out I'm not receiving any body's texts!! I have the 35$ plan with unlimited texting.
03-03-2018 04:40 PM
Lol I know but seriously I was having so much trouble navigating the page 😣
03-03-2018 04:12 PM
@Wafaimran Login to your account to confirm you do have a plan that incudes texting, and is Active. New customers sometimes forget to click that. Do calling and data work?
I have used Lyft without problem.
What is make/model of your phone?
03-03-2018 04:11 PM - edited 03-03-2018 04:14 PM
@Wafaimran, I really doubt that Public Mobile would block specific texts. Asside from that, when did you sign up with Public Mobile, and did you port in a number from a previous provider? If so, are you sure that the number port was completed? Are you able to receive phone calls and texts from others at that number? Any chance UBER has the wrong number for you.
03-03-2018 04:05 PM
@Wafaimranits always best to start your own thread.
Not experienced with Uber. Maybe others will have thoughts.
