03-07-2024 07:30 AM - edited 03-07-2024 07:30 AM
Just want to throw my name in here. I have a oneplus 11 5G and have been with PM since ~November. It worked for MMS up to about a month ago, but no longer. Also I have never been able to use VoLTE, so call quality is low.
On its own the VoLTE thing would be palatable but with that problem plus no group texting, it's hard to justify staying with PM
3 weeks ago
Thank you @softech this worked!
03-29-2024 11:22 AM
Thanks a lot!!!! Works on the OnePlus 7T
03-25-2024 07:39 PM
Perfect! Thank you very much! This fixed my issue!
03-07-2024 12:46 PM
03-07-2024 12:44 PM
OMG this is working for my OnePlus 11 as well. Thank you!!
03-07-2024 08:25 AM
sorry, VoLTE is based on the PM's whitelist and no OnePlus phone is on the list for now
03-07-2024 08:23 AM
oh wow that seems to have fixed MMS. Thanks @softech and @carrierandrew, much appreciated.
Any success in getting VoLTE working on this device?
03-07-2024 08:14 AM
I've been able to get my OnePlus 11 working with MMS again by updating my APN settings, and making the APN field capital letters.
Could just be luck, but I've been trying different combinations for over a week and this finally did it for me.
Don't forget to restart your phone after applying the new APN.
03-07-2024 07:43 AM
did you just update the OS to Android 14? There has been some issue with OnePlus after the Android upgrade
A suggestion is to first try Reset All networks
If that does not work, please go to the APN screen, delete the current APN profile. Then Add new profile and add according to this, please note case-sensivitve and do not add extra spaces. Reboot and confirm the new profile is the only one there and active
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
