Re: Number Transfer
LoverA
I also have the same problem. It has been four days since I transferred a number from Koodo and it is still not connected to the new sim.
1 REPLY 1
hi @LoverA
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone?  If you cannot the port was not done
It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (envelope on top right), check for the number and call
