2 weeks ago
Just wondering if I change my plan before May 1st would I still receive my legacy bonuses?? ( 7.00)
My current plan renews may7th and I guess when it renews at that date it will be on the point system.
The plan I"m intersted in is the 29.00 for 20gigs....if I opt for the 90 day subscription legacy won't kick in.
2 weeks ago
Looks like legacy rewards cant be used, at least thats the way I read it
2 weeks ago
ok thanks Softech...I will only lose 7 days from my current plan ,no biggie. Just makes more sense to get the last kick at the can for legacy bonus but after 1 month this plan may be gone.....we'll see
2 weeks ago - last edited 2 weeks ago
again, we are just customers like you and none of us know the exact plans how PM will handle all the migrations
however, since you are still on old rewards system as of today, so, PM should follow the same plan change for legaacy rewads system as before.
For the longest time, for people on legacy rewards, if they make an early plan change using Change Now, PM will add all the rewards amount back couple days after the plan chnage. So, you should get the rewards amount back in couple days. But even you make a 90 days early plan change, PM will only give you one month of rewards back in dollar first. The 2nd month and 3rd month rewards will be credit to your account after 30 days and 60 days , but those 2 sets of rewards will be in points as your account would have changed to Public Points by then
Also, please be aware that PM does not provide partial refund for early plan change, so, you will still loss some money from the early renewal.
