Phone upgrade
jgorman
I'm looking to upgrade my iPhone. And I just want to confirm in the forum. I can get a Telus phone or unlocked obviously.
But want to confirm just aTelus locked phone will work on PM no issues.
Thanks
Thanks
2 REPLIES 2
jimmyche
This exact issue was discussed earlier.
short anwser is yes - yes
go to the follow link for more discussion regarding this matter
http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/iPhone-6s-Telus-locked/td-p/108739
Bravo and/or mark as solution is this helps you.
Rockdaddy22
Yes, Koodo or Telus locked will work. 🙂
