OS update disabled my data
The_Ryan
Hey, anbody else with a OnePlus3 having issues with the OxygenOS update? When I updated mine my phone no longer registers the SIM as Public Mobile and my data has stopped working.
mjarrett
Yup, same thing happened to me with the OnePlus 3 Oxygen update. Adding a APN using the links in this thread fixed it for me.
McLaren
Yes just update the APN settings from here:  http://productioncommunity.publicmobile.ca/t5/Phones-Hardware/APN-settings/m-p/30197#M4079
And you should be good to go.
stonechucker
@The_Ryan,
This seems to be affecting a number of users with your phone, or other models of that manufacturer.
It seems to be the APN settings.  Please check them, and update if required.
MoreYummy
That usually doesnt cause any problem.
Have you tried to reboot to hard reset the phone or take the card out and put back in?
Hopefully they arent making a similar mistakes as before
