Not Receiving Calls
tessandroger
Hello, I activated and registered my SIM card about 2 weeks ago.  I can do outgoing calls.  However, I am not able to receive incoming calls.  It says "The customer you are calling is unavailable at the moment.  Please try again later."  Please help me fix that.  Thank you!
@tessandroger
It sounds like you are trying to make an outgoing call but you indicated that outgoing calls are OK. Or is that the message someone is getting when they try to call you?
Try rebooting your phone and see if that works by powering off your phone then wait 2 minutes and power the phone back on.
Timer
@tessandroger
rebooting device,
maybe you not complete the port in here,, contact to support team by CS_Agent
dust2dust
Did you transfer a number from another provider? If so did you leave the old sim in and confirm a text from them? Is your old account still working?
