09-16-2018 04:29 PM - edited 01-05-2022 01:49 AM
09-16-2018 10:09 PM
It's working now. I had to delete all of the APNs that were generated automatically, then create the new APN as you all stated, otherwise it did not work. Thank you!
09-16-2018 08:53 PM - edited 09-16-2018 08:53 PM
@glemlin wrote:The APN settings are for any/all devices. You did however mention an exclaimation point, is it possible you're roaming rather than connecting to a Public Mobile tower? Try in the same area checking Network Operators and see if you can manually select Public Mobile.
This will work, but generally it's best to use the automatic setting.
09-16-2018 06:53 PM
09-16-2018 06:37 PM
09-16-2018 06:35 PM
As stated, it's likely you need to manually configure an APN. Steps without having to check another topic:
You do so in settings under mobile networks, create one and add the following:
APN: sp.mb.com
MMSC proxy: 74.49.0.18
MMS port: 80
Once those are in, hit save and select it.
09-16-2018 04:43 PM
As stated above, need to check APN settings...
Here is the section on the knowledge base...
09-16-2018 04:42 PM
@bp1987 wrote:
Hi, I just switched to Public Mobile and am having an issue with cellular data on my Nexus 4. Data is turned on, however when I have a signal I am unable to use data - there is an exclamation mark on the signal icon. I did not have this issue with my previous provider. I tried doing a factory reset on the phone but that did not fix the issue. Any ideas?
You need to check/correct your APN settings in network.
