Loyalty bonus 30gb
paddy5676
How do I use subject instead of my 2g one time data bonus?
Thanks
@paddy5676 wrote:
It automatically reduced my non-expiring data instead of the loyalty bonus data.  That's why I ask the community if something could be done to reverse the situation.
This will need to be discussed with a customer support agent.  Please open a ticket using the chatbot.  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
paddy5676
Thank you for your help.
paddy5676
but that was not what happened.  The system deducted my non-expiring data instead of the loyalty bonus data.
How do I reverse the situation?
Thanks.
HALIMACS
@paddy5676
Your bonus data which expires, should be used immediately following your cycle plan data.
AFTER the bonus data is consumed, any non-expiring data available which was added to the account will then be drawn upon.
It's automatic.
