11-10-2016 10:57 PM - edited 01-04-2022 06:13 PM
Tried to port number from Rogers and got to end of process and received credit card error. Now can't start over. It tells me the SIM is invalid as it thinks it is already active. I tried with a different SIM and now it tells me that my number cannot be ported over. What is going on? I ordered 4 SIMs to port over all our phones but want to get 1 done quickly to make sure there is good signal at our home and at my son's place in Guelph before I do the other ones. Can someone help fix this problem? (NOTE: Is it possible this is related to owing money on my Rogers account. I am in the middle of a billing complaint with them).
11-12-2016 11:51 PM
It works. Thank you.
11-12-2016 07:02 PM
Saray_O,
That is awesome. I will try again later tonight and let you know. I really hope it works so I can take advantage of the great rates right now.
Howard
11-12-2016 04:57 PM
Hi there @hbalter,
I'm really sorry about this inconvenient!
I was able to find an account under your name (number ending on 75-22) and I was able to resubmit the port request with the help of our port team. It should complete within the next 2.5 hours. After it completes, you should go ahead and try creating a new Self Serve account.
Let me know if you need anything else 🙂
11-11-2016 06:59 AM
I have tried but I cannot log into self-serve. It keeps telling me my log-in attempt failed. If I try "forgot password" it tells me it cannot verify e-mail. Basically I don't exist, but at the same time I can't start over.
11-11-2016 12:18 AM
For the first sim, see if you can logon to self serve. If you can you can check or update your credit card there.
