Intermittent failure to send SMS text message on iPhone X
zacharywolfe
Hi there,
I've been having an issue (intermittently) sending SMS from my iPhone, once in a while after i've sent the message it will come back and say it failed to send and I will have to re-send it. I have been a customer for about a year now and i've had this problem intermittantly, it happens usually at least once per day. It has happened with my current iPhone x and my previous iPhone 6S+. I was just curious on whether I am the only one having this issue or if anyone else has it as well.
Thanks
If you have another device from Apple, you can set you phone in the location where it get the best sign, and forward sms and calls via Continuoty to your other device.
Not a great solution, but at least a temporary solution.
zacharywolfe
Actually, I hadn't even considered that. Now that you mention it, I only get 1 bar of signal in my house and it can barely maintain LTE signal so that might actually be the issue.
will13am
No issues here, on various android devices.  Does this failure coincide with having a poor connection?
