Cancel Account
ivomartinich
I want to cancel my account but don’t see an option on my profile and can’t speak to a real person whether through the chat option or by calling *611. I’ve removed autopay, but it won’t let me remove my credit card details.
Luddite
@ivomartinich  In theory, removing autopay should be sufficient. Do monitor your credit card though, just in case there is a glitch.
@ivomartinich
You can automatically cancel your account if you port your number out off PM.
The other options noted by others will take a longer time (90 days) to cancel your account.
MrSpock
@ivomartinich hi removing autopay should be enough but with the new upgrades,removing a cc must be done by a cs agent
 you can open a ticket, to speak to a customer service agent    Click here or if you are having issues with Simon you can send a private message to a CS Agent here:  https://bit.ly/2GGCJzH
dust2dust
You would need to contact the support people to have them remove the card. But according to the terms of service, they can cancel the account for you too.
Or transferring your number out closes/cancels the account.
Short of that then pause your credit card the evening before your renewal and restart it the next day. That would force a suspension for non-payment. Then 90 days later the account will disappear.
Adding - or even use the lost/stolen option to suspend your account before renewal. Then it can't renew. Then 90 days after your renewal date it will disappear.
Timer
@ivomartinich
contact to support team by CS_Agent
