2 weeks ago - last edited 2 weeks ago by softech
I have 4 accounts in my name. Myself and 3 children. Needed to update credit card. 3 went ok, can't log into one. Tried the app. Tried other devices. Tried changing password. Keeps asking to enter new password then locks we out. This is going on for a month. Asked for help here, did all that was suggested. The account has some credit but will soon be shut off unless I update credit card info. Account info.
Phone###-###-####
Can an admin please help? Thank you.
2 weeks ago
Thank you for trying to assist, I tried all the suggestions and just ended up sending a private message and hopefully someone gets back to me in a timely manner.
2 weeks ago
2 weeks ago
Thanks, I was finally able to log in. All solved.
2 weeks ago
I tried incognito, no luck.
please try using browser with Incognito mode to change the password and login , see if that helps
if not, support can help:
