Can't find US Roaming Talk Text Data $20 plan
call-151
A month ago I bought this plan:
US Roaming - Talk Text 250 Data (10-day) for $20
I can't find it in the menus anymore, has it changed? I need to go to the US again.
Thanks.
10 REPLIES 10
Good news. Remember it expires 10 days from now whether you are the USA or not.
call-151
It looks like someone at PM has seen this thread and resolved the issue for me. I just checked my account and the balance is down to $0 and I have the US roaming plan active, so thanks to whoever rectified this!
Thanks everyone for your help with this and have a great weekend!
@call-151 Definitely something odd; it's as if the system thinks you still have the add-on. As suggested, you do need to send a private massage to the moderators to clear it.
call-151
I tried clearing Chrome cache, using Incognito window, and tried using Edge, all to no avail. I am guessing there should be an additional option under the $15 plan?  I also tried to purchase the $20 add-on using *611 but it said I had insufficient funds 😕
I'll probably just buy seperate text and data add-ons, don't really need the talk.
Should there not be an option here? Doesn't seem like a browser cache issue to me.
@call-151 Try again after clearing your browser's cache and turning off any pop-up/ad blocker, or with a different browser, or call *611.
All assuming you can see $20 in Available Funds in your account.
call-151
So I just put $20 into my account ($22.40 after tax) and I still can't see the $20 add-on under "US Roaming Bundle".
I should add that my previous US roaming plan would have expired Aug 30.
Samianauman
As @Luddite mentioned
If you under current add-on then you won't be able to buy again untill it get expired you have to wait for 10 days to pass then buy it again.
** I am not a Mod, please do not include any private info in a private message to me.**
Correct. If it's already listed as an add-on you cannot purchase it yet. Try again the day after it expires. To save time make a 1 time payment of $20 so that Available Funds already have the required amount.
call-151
Hmm, different browser shows the same thing. I wonder, maybe since I already have it under my "Current Add ons" and I have to somehow reload it?
I will try and contact a mod.
cap.png.
Samianauman
It a should be there try different browser. Just to reconfirm I checked my user login and its showing 20 bucks add on for 10 days in usa
Login to your self serve and then click on add add-on if that's doesn't help try calling 611 from your phone or send a msg to mod
Send a private message with your ph#, and your email to mod along your details explaination and they will get back to you.    https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
