Add on for old $25 plan
Harvir_K
Hi i wanted to know is the data add on for the old $25 talk and text plan 3G or is it lte.
7 REPLIES 7
Harvir_K
Thank you guys
will13am
$30 per gig of crippled 3G data!  Time to load up on Telus shares.  My Tbaytel prepaid is $7.50 per gig of unthrottled 3G, less if larger data bucket is purchased.  It doesn't expire as well.
SD08
@Samianauman wrote:
@SD08
o ok thanks
It's only lte if you on talk and text plan only then if you purchase data then its lte ? But if someone have a 3g plan then all data add-on are 3g right ?
Correct.  Smiley Happy
@SD08
o ok thanks
** I am not a Mod, please do not include any private info in a private message to me.**
SD08
@Samianauman wrote:
All data add-on will be on lte speed.
Actually, not all. If you are on a 3G plan, any data add-on you buy will match 3G. See MarieHelene_L's clarification here:
https://productioncommunity.publicmobile.ca/t5/Public-Lab/3G-Data-Add-On/idc-p/169266/highlight/true...
SD08
According to Jeremy_M here, it will be LTE:
https://productioncommunity.publicmobile.ca/t5/Plans-Add-Ons/Data-add-on/m-p/169710/highlight/true#M...
Also, from the fine print on the PM plans page, note # 7: "If you have a Talk and/or Text Plan only with no data, the Data Add-Ons available to you will be defaulted to 4G LTE speed"
