3 weeks ago
Is the new 34$ Can/Us plan , 50 gigs or 50 gigs full speed and unlimited at a reduced speed?
3 weeks ago
@Wyattweir - The $34 50GB Canada-US plan includes 50GB of data. No unlimited data at reduced speeds. So when you reach 50GB a Canada-US $34 plan you won’t be able to use data unless you buy an add on for the US or Canada.
Also if you are in Quebec you can get a Canada-Wide $34 50GB + 10 bonus GB with unlimited data. *No US roaming on the unlimited plans.*
