$10 plan voice mail charges
shuffle
I'm on the $10 prepaid plan.
When I call my PM number I've enabled the extended absence option but it still shows a line item on my usage at around 7 seconds.
Here are my detail:
savvy
@shuffle wrote:
Your answer confused me a bit until I looked around.  There's another place in "My Pln" with "view my usage."  The second part a little lower down "My Data and Add Ons" tells you how much you've used.  The first log shows all your transactions.
How confusing!!
There is a learning curve I find here, but once you get to know most of it, it will become second nature. Smiley Happy
Yes, it can be confusing.  As long as your minutes don't get used for those 7 seconds, you should be fine....
shuffle
How confusing!!
Dunkman
@shuffle
Does the 7 seconds count as one minute towards your 50 minute plan?
