02-09-2024 10:14 AM - last edited on 02-13-2024 09:42 AM by Dunkman
since pm doesn't offer wifi calling option, is there an app that works with my existing phone number to make phone calls over wifi since signal in my house is low to non existent.
02-09-2024 11:53 AM
I use WhatsApp but the both parties calling and texting each other both must have this app.
I also use TextNow with a secondary number plus I have the TextNow SIM so I can make free calls and texts without the need of wifi while in the USA.
02-09-2024 11:17 AM
There are several apps that you can use from the App Store. It's up to your preferences. I personally use text now. What I like about text now is that I get a different phone number so I can sign in on that app and use that without using my phone number.
If you want to use your phone number then you can use WhatsApp. I use WhatsApp. What's up show as your number, the other person also have to have WhatsApp to use it so that could be a down fall.
With textow the other person doesn't have to have it. But with each of these, you have to have good signal for them to work.
02-09-2024 10:46 AM
Hi 🙂
I use the free TextNow app to talk/text on WIFI. You can choose a local phone number in the app. You could forward your PM phone number to the TextNow number. This might work for you.
02-09-2024 10:22 AM
@chantau1 : My guess is no, as the carrier has to enable wifi calling on their side. If the carrier doesn't support it you cannot use Wifi calling with any app. However of course you can use apps such as Signal or Whatsapp which uses wifi/data for making calls (which is different from Wifi calling).
