want to upgrade to 4G 30GB plan for only $29/month plan
sohd
Hi,
I would like to upgrade to 4G 30GB plan for only $29/month plan.
Please let me know who can do it.
Thanks.
8 REPLIES 8
sohd
Thankyou very much Chalupa_Batman , your recommendation worked and i'll be upgraded to the 29$ plan from the current $25 one.
Why wouldn't they? Were you downgrading? That could be why. If you're upgrading, spending more money, they will gladly change it.
HI @JenCanada
we are happy as long as you get a good deal
Telus will be as happy as well as it owns both Koodo and PM 🙂
JenCanada
Public Mobile Customer service would not give you that plan so I moved to Koodo for $34 and 50G data and other perks..
Please come back and let us know if it worked! We're rooting for you!!
sohd
Thankyou for the reply. I'll try to follow through. Thx!
@sohd  Best to ask support for this , they can sometimes help others have reported getting this plan
send  a  private message   To CS_Agents
Chalupa_Batman
If you're looking to upgrade, you can ask politely to a CS Agent. Here's the link
I upgraded from the $25 5GB 3G plan to the $29 30GB 4G plan. Just note, they will only "upgrade" and not downgrade. I give full credit to @Handy1  and @kb_mv for sharing this with the community.
Reach out to a CS Agent and ask very nicely.
