02-20-2022
11:21 PM
02-21-2022
12:05 AM
computergeek541
Hi there,
I have activated the sim card. Because I'm abroad now, I want to know how to use the number abroad.
I don't get the exact number of my sim card because I activated the sim card online.
Please help me to use the number.
Thanks,
02-21-2022 09:23 AM
PM does not provide services beyond Canada except US if you buy appropriate add-on.
If you activated PM SIM while abroad, at least you can create self-serving account and confirm everything is in order and ready for use when you are back.
02-21-2022 05:42 AM
How long will you be outside of Canada? Pm only has limited roaming options for use in the US. There are workaround options but your sim card would have to be in Canada for them to work. If your pm phone # is very important as a way for people to contact you then you could make use of call forwarding and a text forwarding app if you have someone you trust in Canada willing to help you achieve this by using some of the options in the spoiler below.
Have a trusted friend or family member order or buy a new unactivated pm sim card. They give you the sim card # and you perform a sim swap in your account using the email 2FA option. Your friend can then put the pm sim card in their phone and call forward your pm phone # to your voip phone # that you have chosen (from textnow, fongo etc....make sure you choose a Canadian phone #).
If you need text messages as well then if your friend has a spare smart phone to download s text forwarding app to they can set up text forwarding as well and leave your pm sim card in the phone that is left powered on and plugged into a charger so that it stays powered up.
You will then preferably have a local sim card with a cheap and plentiful data plan and you will recieve you pm calls ( and texts if you can) on your voip number while connected to mobile data or on wifi. If you are unable to make this arrangement then its best to schedule a change plan on next renewal to the $15 plan (regardless do this anyways) and suspend for 85 days or so....reactivate before day 89 at the latest with $15 plan for 30 days and suspend again for 85 days....and so on til you come back to Canada.
If you are on the rewards program and you need your pm phone # then its worth paying the approximately $39 per year (355 days) that it takes to suspend and reactivate your account services.
Most important mark on your calendar day 85 of your suspension and day 90. Do not forget when you must unsuspend your account via lost/stolen and/or pay and reactivate your service so you don't lose your phone number and account. Happy travels and Stay--Safe!
To pre-verify your account include your full name, address, email, phone # and 4 digit acct pin #
02-21-2022 03:19 AM
You can only get roaming if you are in the USA. I would suggest you get a local SIM where you are located...it would be cheaper for you.
02-20-2022 11:34 PM - edited 02-20-2022 11:34 PM
@sssopy You can't use PM service outside of Canada & USA (with roaming Add-on).
Which country are you in atm? What were you planning with PM?
02-20-2022 11:31 PM
@sssopy No, PM service is only within Canada, or US with Roaming add-on. The service would not work in anywhere else.
You didn't get the exact number of the SIM card? how did you activate online? When you activated, you did need to put you the SIM card number. Or someone else did it for you?
So, what you trying to do with the PM SIM abroad? It cannot be done. but you want to receive calls when you are aboard? If so, then get a VoIP app like TextNow. You will get a Canadian phone number with the app and you can receive calls and make calls as long as you have Wiif or local Mobile Data
02-20-2022 11:27 PM
@sssopy You cannot use Public Mobile abroad.. Only in US outside of Canada, and only if you buy roaming add-ons..
