update creditcard
gec
trying to update creditcard but dont know what email was used to set account up.
the password reset is no problem as it is sent to the phone but when trying to recover the email its sent to the gmail or whatever to recover and i dont remember what email was used to set up the account years ago
Lolo_1234
If you don't have a way to access the reset email then you'll need to contact customer support - you'll fin the link in my post below 🙂
gec
problem is "forgot email" sends an email to the phone not a text and i dont have access to the email account
Chalupa_Batman
Hi @gec
This is very easy to do. Go to Public Mobile to log in. You will see THIS at the bottom.
Click forgot email. It will then send info to your phone. This should at least get you at a starting point.
Then this is how you change your credit card.
How to change your credit card number
First and foremost, if you are changing your credit card information, you need to add every piece of information about the credit card like it was your first time. Even if it’s already auto filled, do it anyway.
When you log in to your Public Mobile account, go to the Payments button.
On the right hand side, click on Manage Subscription.
Then click on Manage Payment Method and remember, change and edit everything even if it’s already auto filled.
Created by Chalupa Batman
Dunkman
@gec
In the past, Public mobile use to send a welcome email when you first activated account.  You could check your various email accounts for this welcome email.
Lolo_1234
The best would be to contact a CS agent 🙂
Just click on this link to send a message : https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
