transter number
611jcc
Please port this phone #************ from my koodo account to my new Public mobile account phone #***********.
Thank you very much!
Kit
Edited by ShawnC: Removed account and phone number
Thanks for the tag @brettster99
Murse20
You can port your number via self serve account. You will need a new number first from public make sure you do not cancel koodo until you port over. Once PM is set up go to self serve and port your number. It takes about two hours but it works. Click on the Question mark on PM site and type "port number" Virtual Simon can guide you through.
Welcome to public mobile 🙂
The above posts have the instructions to port your number over. If you used a referral code when signing up the $10 signup bonus will be applied within 72 hours.
Have a great day and enjoy the savings!
Triguy
You will need the assistance of a moderator.
To complete your port-in request, please open our chatbot via this link and type in “port request” to be put in touch with a Moderator.
Here is more info.
https://productioncommunity.publicmobile.ca/t5/Announcements/Number-transfer-in-Self-Serve-impacted-...
popping
@611jcc
Please edit your post to remove your phone # as your post can be read by anyone if you don't want any spam calls.
Create a moderator support ticket for help using this link https://publicmobile.ca.ada.support/chat/
Tell SIMon what is the issue (important) - "port request"
brettster99
This is a public forum. Please remove your #
Edit: @ShawnC13 - No problem. Thanks for the quick response
