2 weeks ago
Can I get text messages from eg. What's app while in Europe?
2 weeks ago
Thanks for the info.
2 weeks ago
Hi,
As long as you have access to internet, using wifi or a data only esim card (eg: Airalo, Holafly, etc), then you can use WhatsApp. I've travelled to Europe many times and used the esims purchased through Airalo. Very easy setup using their app and great support, reasonable prices.
Happy travels!
2 weeks ago
Hello @lagoon41
Public Mobile only works in Canada and the US. If you are looking to use Whatsapp and other VOIP programs, you will be required to purchase a data only SIM card. Here's a link to a popular site that sells them.
2 weeks ago
hi @lagoon41 you cannot get sms text in Europe. PM has no service there.
but WhatsApp will still work as long as you have wifi or local data
2 weeks ago - last edited 2 weeks ago
@lagoon41 wrote:Can I get text messages from eg. What's app while in Europe?
Whatsapp can be used, but you'll have no service from Public Mobile. Another internet/cellular servcie would need to be used for the connection.
