12-19-2021 01:25 PM - edited 01-04-2022 04:53 AM
perhaps someone can assist?
i have a public mobile account that i opened for my daughter a few years ago and opened using my email address.
when i tried to change the email address to my daughter's email address, i was told by the CS that the email was already in use with a different public mobile account.
This is not possible as she does not have nor ever had another public mobile account or account with any cell provider and having gone through her email, she has never received anything from public mobile regarding an account activation.
any solutions or suggestions?
12-19-2021 05:25 PM
@ctrller wrote:turns out that the cs agent miscommunicated the information to another cs agent and the issue has been resolved.
thanks to all for their input and help!!!!
Happy that it got sorted out. check the Security Question in My Account and make sure you able to answer it. If you miss forgot the password again, you can reset it yourself with the answer to the Security question
12-19-2021 04:58 PM
I just had a recent experience with what was probably a new CSA. An old timer stepped in and everything got sorted out... and then some. Took a couple days though.
So yes, if you're not satisfied with replies or you're being misunderstood...escalate. The old timers know what they're doing.
12-19-2021 03:38 PM
@ctrller my guess is, that the CSA you were dealing with messed up.
Glad you went back to them to get it sorted out.
12-19-2021 03:14 PM
12-19-2021 03:12 PM
12-19-2021 01:47 PM
will try this route.
sent in a request to reset the account and i'll see what happens! thanks for the suggestion!
12-19-2021 01:41 PM
you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent by Submit a Ticket,
Good Luck..
12-19-2021 01:35 PM
@ctrller try using forgot password link.. enter your daughter email and see if you can answer the security question
12-19-2021 01:33 PM
@ctrller wrote:perhaps someone can assist?
If you've already contacted CS and were told the email is no good, there is not much you can do but use another one. You can use aliases if you want, so communications from PM will go to the main email account.
12-19-2021 01:30 PM
Create or decide to use another email account. Contact a CSA and assign a new email to YOUR account.
