sim card with purchase of phone
lmcharleson
Do you know if you purchase a used phone does it come with a sim card?
7 REPLIES 7
public_user99
Phones purchased from public mobile come with free Sim.
Yummy
Yes, all refurbished phones should come with free SIM, as per offer.
Good luck getting it though, as many reported they are missing SIM 😞
@Anonymous
Great!
 @BKNS27 : I just tried it and a SIM automatically showed up (at $0). The problem seems to be fulfillment.
@lmcharleson
Yes you do but a add PM SIM to your order and it should show $0.00.
@lmcharleson   If you meant PM CPO phone, yes, it should come with it
However, since last week, many reported that they miss putting one in.
So, if you have ordered a phone and don't see the SIM, open a ticket with CS Agent
if you are to order one, keep any eye on it when you receive the phone
dabr
@lmcharleson    Yes, if you're purchasing the phone from PM, you should also get a free SIM included.
Edit: Here's the link to the phones and conditions:  https://www.publicmobile.ca/en/phone-section
