02-15-2022 03:08 PM - last edited on 02-15-2022 10:11 PM by computergeek541
sim card phone xxxxxxxxxxxxxx is not ringing but goes to voice mail directly.
I have tried putting this sim to different phones , it is the same problem.
Phones are working well with other sim card.
So, the problem is this sim p
02-15-2022 10:10 PM
@computergeek541 , would you please be the phone number eraser?
Is your Do not disturb option accidentally turned on ?
OR, do you have the setting set where you only received calls from people on your contact list?
OR, did you recently port over a number into Public Mobile from another provider?
Cell ports can take 2-3 hours to complete. In this case you will need to accept an SMS text from your old provider's SIM card.
Landlines/voip number can take 3+ days to complete.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
If issues porting or transferring a number to Public Mobile, and it has been over the allotted time it usually takes to complete, submit a ticket here for help:
OR, see you inbox,
I will also private message you the porting phone number, but please feel free to ignore it if this is not a porting issue.
02-15-2022 06:53 PM
Could you click on the little arrow thingy on the right side of your post to edit out your phone number please? You don't want the ensuing spam and what not that you will recieve by posting your number on a public forum.
As mentioned run thru the troubleshooting tips in this order from easiest to more complex and test after each one to see which one is the fix?
Report back your findings we can explain what the likely issue is causing your calls to default to voicemail.
02-15-2022 06:18 PM
It sounds like the problem is your phone cellular network setting not set on 3G/WCDMA.
Just manually set the cellular network setting.
02-15-2022 04:39 PM
Please hide your phone #...
02-15-2022 03:13 PM - edited 02-15-2022 03:13 PM
Your outgoing calls are ok?
Which area is yours (Province/City)?
try to put the network settings to 3G Only/WCDMA and see if it works
If still fails, open a ticket wtih PM Support and see if they can find out any problem in your area:
1. For faster response (2-48 hours), Click on the bubble in the lower right to request CS Agent assistance, or use this direct link: https://publicmobile.ca/chatbot.
Start with typing "Submit a ticket", click "Contact Us", click "Other" from the choices, click "Click here to submit a ticket". Then follow to complete the ticket submission.
2. Or you can Send a private message to the CS Agent here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
02-15-2022 03:13 PM
Hi @Maureen5108
reset SIM, take out SIM, re-inserting SIM and power on,
try toggling airplane mode off/on,
try manually selecting network "3G only" or WCDMA only,
and Rebooting device..
