08-14-2023 02:33 PM - last edited on 08-14-2023 05:40 PM by computergeek541
so i got a text says i need a new phone (old lg g5)
samsung a53 5g model cwb4 and above
but i only see models that start with
SM-A536W will it work
08-14-2023 05:21 PM - edited 08-14-2023 05:35 PM
Do you send those pics through texting? The text you got from the company is actually about the APN settings on the phone. Use these settings without touching the other settings. Save it, select it as the active APN, go in and out of airplane mode to use it. And do you use the phone for browsing web pages when not on wifi?
MMS proxy: mmscproxy.mobility.ca
MMS port: 8799
08-14-2023 02:44 PM
Truth be told, I'm on 3G $15 plan myself and send texts and pictures as well. Unless you're doing hard core surfting and download and stuff like that, why pay extra for 5G speeds if you're happy with 3G? It's all about saving money here at Public Mobile.
08-14-2023 02:41 PM
i still use 3g but do pic and text with wife
08-14-2023 02:36 PM
Do you text any pictures? Do you use the phone for internet access not on wifi? If not then disregard the text.
08-14-2023 02:36 PM
That model is the Samsung A53 5G, so yes it will work on a 5G Plan
08-14-2023 02:35 PM
Yes, A53 (SM-A536W) will work!!
08-14-2023 02:35 PM - edited 08-14-2023 02:36 PM
Your Samsung SM-A536W is a 5G phone and should work.
Make sure your phone is updated to the latest firmware/software.
