same text message being received every day for the last 3 days
Tardismaster
I have been receiving the same text message every day for the last 3 days . If I click on download, it does not download. I then delete it but it comes back every day at 9pm
11 REPLIES 11
Tardismaster
the wifi was not on at the time, so thank you for your help
Tardismaster
thanks but the problem disappeared by itself
Tardismaster
thank you but the message stopped by itself after 4 days
Tardismaster
thank you but the problem disappeared by itself
Tardismaster
problem solved by itself
Tardismaster
the problem disappeared by itself , so thank you anyway for your help
BlueB
@Tardismaster
We'd need a bit more information, such as if you know this person/number or if you're able to see any contents of what that message is.  Typically, messages are delivered to your phone once and you'll have to download (MMS?) it if your phone didn't already.  @hTideGnow makes a good suggestion to ensure your Data is on for MMS to download properly.
Have you tried powering off + on your phone?  In a rare case, this could help reset your phone on the network and also any cache that your phone has been using.  Let us know - we're curious what comes out from this!
Tiprix
@Tardismaster
If you don't know the sender, it could be a spam text.  Be careful clicking on random links.
@Tardismaster   would it be a MMS ?  If so, you will need to turn on Mobile Data and download
also, try to clear cache of your Message app
Quigley
@Tardismaster
If the text is from someone you don't know or aren't expecting, just mark / report it as spam and block it before you delete it.
juanpablo03
is it a person who sends you the messages?
