referred by a freind , but my freind didn't get reward notice
MH01
Hello ,
I might didn't apply my friend refer code successfully. can some one check it for me , I just active it today to get the 25 dollar rewards.
Thanks
MH01
Thank you , will wait and contact
MH01
Thanks, I will wait a bit
then contact CS_Agent
@MH01 your friend should see your number in his friend list on My Rewards site within a day, and you should see the usual $10 friend credit within 72 hours.  For both of you, the $5 per month should start in the next couple days.
I suggest you to hold on, with the full 72 hours before you open ticket with PM
Timer
@MH01
but your friend will see it your last 4 digit number at Login Page Rewards  press at refer-a-friend
after 24 hr your friend not showing your last 4 digit then contact PM support team by private message CS_Agent  with your friend code to them can be check in..
MH01
yes Thanks
dust2dust
Are you HM01's friend? 🙂 Click on the Chatbot link at the bottom to get help from the support people.
