please help! @cs_agent
PikachuThunder
@CS_Agent
Hi! Please help me! Could you please send me a private message? Can you please send me a phone transfer confirmation through email? I somehow missed the first one when I changed my number on the 19th. I am asking for email please because I can't receive text messages and phone calls at all because I didn't answer the text confirmation on time.
PikachuThunder
I will take a look at it. Thank you for helping me!
@PikachuThunder   are you trying to port in number from another provider to PM and missed the message from the other provider?
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
PikachuThunder
Okay, thank you!
@PikachuThunder  If this is a porting issue there a number for live support to restart the port request and get a status update on the port . Will send it to you private message
@PikachuThunder  support won’t message you . You need to message them and here’s how .please
Message support directly
  • while your already here and logged in the community you can send a private message   To CS_Agents click >>>here.<<<
