04-21-2020 04:10 AM - edited 01-05-2022 10:28 AM
04-21-2020 11:52 PM
All phones sold privately are...BUYER BEWARE....there has been too many posts on the community about someone's phone suddenly not working with the message " Not registered on network". Its almost always a private sale that gets blacklisted a month later and the OP is out hundreds of dollars. It is not recommended to buy off online classifieds.
04-21-2020 10:56 PM
you can find good unlocked phones in kijiji
04-21-2020 11:26 AM
You need an unlocked phone that is compatible with public mobile.
04-21-2020 11:22 AM
@marylou1976 At the moment (and probably near future) PM is bring-your-device provider. So, have to have your own phone already to buy SIM and start using PM services.
04-21-2020 09:13 AM
You have to provide your own phone. Are you looking for an Android or iPhone ? You can buy them online from sites like Amazon.ca and AliExpress depending on what you are looking for.
04-21-2020 06:21 AM - edited 04-21-2020 06:24 AM
Public mobile doesn't offer phones or contracts. You just purchase a $10 sim card either online or in store (sometimes they are free if you activate in store.) Choose a plan and activate your sim card. You can pick a new phone number or port in your number from your current provider.
Bring your own phone or consider buying one from amazon (the Umidigi A3, A5 pro and F2 are popular and very good value $100 - $250). You can also look at refurbished phones take a look at this site:
04-21-2020 04:26 AM
Here are some links that may assist you with Public Mobile:
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Getting-Started/ta-p/162
https://productioncommunity.publicmobile.ca/t5/Knowledge-Base/How-to-Activate/ta-p/251824
04-21-2020 04:19 AM
ok thank u
04-21-2020 04:16 AM
@marylou1976 wrote:can i get a phone will public mobile
You need to bring your own phone to Public Mobile. They do not sell phones.
