10-16-2022 06:47 PM - last edited on 10-17-2022 04:03 PM by computergeek541
your sim card has destroyed my wife's phone, the phone was working perfectly under virgin mobile, I activated the public mobile sim card and now it goes straight to voice mail, i have done everything to get it to work, profoundly disappointed
Tim
Help !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
10-17-2022 03:59 AM
@KarenVeyIf you put the Virgin SIM back into the phone, and it still works and can receive calls, that will be a strong sign that the number port did not complete. Normally as part of the porting process the "losing" carrier SIM will immediately stop working once complete, and incoming calls should then route to the new provider.
If incoming calls are still arriving at Virgin, You'll need to open a customer service ticket to inquire about the porting status, and/or retry the port.
10-16-2022 10:27 PM
Incoming calling going to voicemail is a sure fire sign that porting did not complete. Did you reply YES to the PAT (porting authorization text) within 90 minutes? Did you use the IMEI # of the phone? Or the account #? Did you get the account # yourself or get it from customer service at Virgin? They have been known did give out the wrong account#.
Regardless you have been given the telus porting department phone #. They will reinitiate the port request for you.
10-16-2022 09:07 PM
Wow Karen. Maybe you should be asking for help with your issue. Obviously you’re not tech savvy if you think a SIM card “destroyed” the phone.😂
This community is for customers to ask questions and gets answers. It’s definitely not a complaint forum Karen.🤪
10-16-2022 07:48 PM
Try these fixes:
10-16-2022 07:24 PM
Hi @KarenVey
with PM, voice is on 3G. But your data on LTE , so if you have 4G plan, your data will have the LTE speed
10-16-2022 07:15 PM
yes, ported from virgin mobile, replied to virgin text, paid for lte , phone only works on 3t
10-16-2022 07:08 PM
SIM cannot damage phone unless it is designed to do that on purpose.
When did you sign up with PM?
Did you port your number?
10-16-2022 06:56 PM
Hi @KarenVey haha. Sim won't destroy phone
did you port in the Virgin #? Did you get thr text from Virginia and did you reply YES? I think your porting not done. The VM is actually still Virgin VM. Call PM porting team and they will help I will message you the number. Check Inbox on top right
10-16-2022 06:51 PM
I don't think the sim "destroyed" the phone !
Have you a different unlocked phone you can try the sim in ?
Did wife just recently port her Virgin number to PM ? If so, did she follow the directions for porting to PM ?
