phone rings busy when people call me
jc11
For 2 months my phone has rung busy when people call me.  Text is working and I can call out.
11 REPLIES 11
Nezgar
Ok so ##21# would reset "unconditional" call forwarding - also try ##004# to reset "conditional" call forwarding.
Secondly, try switching your phone to 3G mode, not LTE and see if incoming calls work in that mode.
Lastly, Did you originally port your number from another provider? Sometimes this can happen if the number was not successfully ported, or only partially ported. If so and you still have the SIM from the previous service, you should double check that the port caused your previous service to be cancelled. Incoming calls are what the port deals with... And don't call the previous carrier to cancel - the port takes care of that automatically.
darlicious
@jc11
While you are waiting. Toggle airplane mode on. Power off phone. Wait a couple of minutes. Reboot. Toggle airplane mode off. Test call your phone.
jc11
Thanks very much.  I have sent the message.
jc11
I have contacted customer service - thanks very much
jc11
Thanks, didn't set up call forwarding and have tried that as suggested but no difference.  I can receive text.
0PX9O4
@jc11
For the benefit of other customers, please let us know what was causing the problem once it is sorted out.
jc11
No but thanks - have also tried doing a reset and removing the sim card - disabling and restarting service.  I have contacted customer service thanks for your help.
0PX9O4
@jc11
You can keep waiting here to see if anyone else has better ideas, or you can send a private message to CS_Agent with your account details so they can investigate for you.
jc11
says call forwarding has been disabled but still ringing busy when I call from another phone.  Thanks very much though
Also had never initiated call forwarding
darlicious
@jc11
Did you port in two months ago? Port in with your phone number call forwarded?
0PX9O4
@jc11
This could be due to call forwarding having been set up.
Can you dial *#21# from your phone and share the result that it shows?
