phone number not porting
micahjkennedy
I need customer service phone number - number hasn't ported over after 24 hours and we cannot log into our account because 1 time code does not come to our number and there is no alternative listed. we are porting 3 numbers and have the same trouble for 2 of them, and then one of them appears ported but isn't receiving every call and text
7 REPLIES 7
micahkennedy
Sorry, my username is just gone for some reason. had to create a new community profile and username. Could you please re-send to the new username?
micahkennedy
Sorry, my username is just gone for some reason. had to create a new community profile and username. could you re-send that private number to me on this new username?
micahkennedy
Sorry, my username is just gone for some reason. had to create a new community profile. Yes, we used 3 different emails
hairbag1
@micahjkennedy
you've used a different email address for all 3 accounts...correct ?
@micahjkennedy  No worries I’ll send you porting  team number private message and get it fixed
@micahjkennedy
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
