2 weeks ago
i bought 4 vouchers and pay in full...3 vouchers worked and the 4 voucher said try again later? there is a problem with my voucher, can I call someone to give them my voucher number? or do I have to go back to the store I bought the voucher...i said clearly no refunds
2 weeks ago
Agent took care of my problem. They made the correction with my voucher in less then 2 days..thanks
2 weeks ago
yes the first 3 vouchers worked, its just the 4th one. This never happened before. They are 40$ vouchers I bought. I tried on another phone, my cell phone , its said we can not process this transaction, the other 3 vouchers say its been used try another one, and through my account..its shows the transaction with a green check but doesn t add the 40$ to my account, I did this again 2 hours later and same problem, hopefully I didn't lose my 40$..I don t think the pharmacy i bought it can help me..thanks
2 weeks ago - last edited 2 weeks ago
Customer support does not open until 9am et. You should get a reply within a few hours after that although during exceptionally busy times it may take up to 48 hours to recieve a response.
Have you tried again to add your fourth voucher? If not try again via 611.
2 weeks ago
how long does it take for a response from an agent ?. Its been a few hours now. thanks
How quickly did you add them to your account? Normally you can only make or attempt to make two payments by any method before waiting out one full hour before trying again.
Calling 611 from your phone or 1 855 4PUBLIC from another phone and entering your 10 digit phone # is the best method to add vouchers as there is a delay when entering them thru your self serve account.
You can also check their validity wait times in the Voucher Catalogue.
Edit: Scratch that. The Voucher Catalogue has disappeared?
2 weeks ago
If you have not already tried…call 611 from the phone and add the voucher. I find this option easier.
2 weeks ago
you got them all in the same store on the same day?? some vouchers need 24 hours before active, but if they all bought at the same time, I think that does not apply
Ask agent to check. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
